Peugeot 307 - Voir le sujet - BSI reboot . I need to clarify some points - Forum Peugeot 307 - 307CC - 307SW
ladanow
MessagePosté le: Ven 28 Mai 10 à 13:22    Sujet du message: BSI reboot . I need to clarify some points Répondre en citant
Hello , i need to reboot BSI to repair some fault,,
I want to clarify points 5,6,7,9 in the following steps
Before sending the unit try the BSI Reset procedure as this may cure your faults:
1- Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
2- Ensure all doors are closed and remove key from the ignition.
3- Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
4- Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
5- Switch on the side lights through the driver's window.
The side lights are the flashing lifgt when i turn left or right ? the button with triangle ? or which button ?
6- Switch on the ignition and check system's functionality.
Does it mean to put key and turn it for steps only with out turning on the engine ? then i check the system functionality from screen with the buttons in the cassette ?
7- Hold lock button on key down for 10 seconds.
which one is this button ? the one beside the trinagle button which lock all the car doors ?
8- Remove key open & close door test central locking system.
9- Start the engine and complete the system's check.
how to make system check ?
Failure to follow this procedure could result in incorrect operation of many BSI related items
gg
Seeeeb
MessagePosté le: Ven 28 Mai 10 à 13:32    Sujet du message: Re: BSI reboot . I need to clarify some points Répondre en citant
Hello ladanow,
please follow that & ignore the previous procedure :
- Switch off everything and open the door driver
- Wait 3/5 minutes
- Disconnect the battery
- Wait 5 minutes
- Reconnect the battery
- Wait 2 minutes
- Start the engine
This procedure's OK for several members here Wink
